Go Back   The Toyark > Toyark Toy Forums > Creative > Customs General Discussion
Question about 3D printing replacement parts?
Old 09-05-2018, 05:11 PM   #1
Zictor
Zictor's Avatar
Hey, I’ve been looking for a reasonably priced Legacy Megazord on eBay and Finally made a purchase, however the back cannons are missing. Fortunately I’m a 3D modeller and figured I can just model and get the parts printed... but I’m scared I’ll get the scale wrong or something... has anyone done this before and do you have any tips?
Also if you just do happen to have a spare pair of official ones laying around I’ll just buy them from you 😂
I want the following figures: All of them. Thank you and goodnight.
Zictor is offline   Reply With Quote
Zictor
Send a private message to Zictor
Find More Posts by Zictor
Old 12-17-2018, 05:14 AM   #2
TrentTroop
Hey there. I do a lot of 3d printing work (I run the Prize Inside! Shapeways store, I can't link at the moment because I'm under my first 10 posts)
I'd be glad to help out.
The first think you want to do is get a pair of digital calipers if you don't have ones already. Once you have it you'll wonder how you got along without.
The rule is measure thrice, print as many times as needed to get it done. If you're using a home printer this is easy enough, if you're ordering from a service like shapeways I tend to recommend either mocking up a part that has the connection port with a number of slight variations on thickness/taper to figure out which one works before printing the connector attached to a larger and more expensive part. Or you can do the connector and main part in two pieces, so that if the connector comes back wrong you can just replace that, not the whole piece.
Typically, anything that pegs in should have a slight taper. For Transformers guns, for instance, the average peg-grip is 5mm in diameter, 8mm tall. For shapeways, in addition to beveling the peg at the end, I also make it so its 1% narrower at the end, and 1% wider at the base. This produces a good friction connection with the way Hasbro makes their 5mm ports/pegs in the Shapeways materials.
It's probable that the Megazord is going to use MM as its measurement of choice, so I recommend when you're doing your measurements to stick metric if at all possible.
Let me know if you have any questions.
TrentTroop is offline   Reply With Quote
TrentTroop
Send a private message to TrentTroop
Find More Posts by TrentTroop
Random Figure from 3D Printing ashmarinxyz Customs General Discussion 2 12-17-2018 05:19 AM
Making Figures with SLA Resin Printing ashmarinxyz Customs General Discussion 0 10-31-2017 02:53 PM
Making Your Own Figures with 3D Printing ashmarinxyz Customs General Discussion 2 09-05-2017 04:56 PM
Neca Batman cape replacement question iLLest Customs General Discussion 2 01-15-2016 10:44 PM
Making toys with 3D Printing? shawnmichaels Customs General Discussion 1 11-15-2015 12:36 AM
Question about 3D printing replacement parts? - Toy Discussion at Toyark.com
